Nice work! (n/m) posted by Spongerider :) on September 13, 2010 at 10:52 AM
I can't find the pictures I took to illustrate this right now but check all the screws on the back of the cluster which hold the meters in place and make sure they are tight. If they seem a little loose, take a couple out and look at them. If you see an area about 1/4 inch long toward the top of the threads that look dark or corroded, use a wire brush or a grinder with a wire wheel to shine them up. They can also cause bad connections to the gauges.
